Window Problem HELP!!!
Discussion in 'Audio & Electronics' started by Dawgfan54, Jun 3, 2013.
  1. Roush PSD Interceptor
    Rockauto has a EO PRO master switch for $39.79 plus shipping with a 2 year warranty,
    if ya decided to replace it, or 2004-08 Crown Vics and 2004-08 F150s
    use the same switch if ya go used at a scrapyard or ebay.
    RockAuto Parts Catalog[year_1993]=true&ck[mkt_US]=true&ck[mkt_EU]=false&ck[mkt_CA]=false&ck[mkt_MX]=false&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=klnci5l6ltomt1a6krgb69es91
  2. Dawgfan54
    Dawgfan54 Full Access Member
    Are we sure it's the mini computer that's the problem? I'd hate to spend money and it not fix it ya know?
  3. cowboy
    I want to say yes.
    Second thought can you measure the voltage coming from the switch to the window motor? maybe it's not getting the full 12 volts which means the switches are still bad because they are not cleaned enough.
  4. VanoFord
    Got a friend w/ a 12th gen? swap the master switch and watch it all work. then you know you're money will get used wisely. have faith... you came to us for an answer but now you don't like the one we are giving? :Wedgie: :joke:
  5. Roush PSD Interceptor
  6. Dawgfan54
    Okay first off, I wanna say thank you to all of you guys for helping me it's been a pain in the ass but I've finally isolated the problem, like you guys suggested I swapped out a switch panel that I knew worked (my fathers from his 06 2wd) and everything worked like a charm!
    So I just ordered the switch from amazon, I got lucky cause it was the last one they had in stock, and I'll let you guys know when it gets here, cause I sure as hell don't know how to swap it out with the old one without breaking it.
  7. Darth Bama
    Damn all the switches I was pricing for my 2002 were like $75-$85!
    Guess I wasn't looking at the right places! :jester:
    :D.
  9. Dawgfan54
    Got the new switch in today popped it in the panel and it worked like a charm! Thanks guys!
  10. iowaredneck
    Awesome
    sent from area 51
