2004 Expedition faded cladding fix
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by Dkhenry, Jun 19, 2013.
  1. Dkhenry
    Dkhenry Junior Member
    Atlanta
    Hey guys I just bought a 04 Expedition XLT and of course the cladding was faded and made the SUV look bad to me. I read several post trying to find the best solution to this besides buying new ones and couldn't find anything that worked. I finally got frustrated with trying to get the color back and painting that just scratched off to easy and started experimenting with different things and I found something that worked for me. My cladding was in very bad condition and I have before, during and after pics. I used brake fluid and poured a little on a scotch brite pad and scrubbed the cladding til the white oxidation was gone. I removed the cladding from the expedition because "BRAKE FLUID WILL DAMAGE PAINT". Once I got the oxidation off I rinsed the panel with water, dried it off and then applied CAR WORX restoration refinish. I'm not sure how long this will hold up but I assume a while since the oxidation is removed and the restorer is like a sealer. This is a time consuming process, and Im not responsible if anyone tries this and causes any damage. ImageUploadedByTapatalk1371620014.052210.jpg ImageUploadedByTapatalk1371620027.867477.jpg ImageUploadedByTapatalk1371620042.551536.jpg ImageUploadedByTapatalk1371620053.717187.jpg
    Nice. I used the rustoleum bedliner in a can on my aunts. Just taped it off real well and sprayed about two cans
    sent from my igloo
  3. Dkhenry
    Atlanta
    I thought about Bedliner too, but I was really looking for a way to bring back the original color. Hope it last
  4. iowaredneck
    Nice work and write up man
    sent from area 51
  5. VanoFord
    night and day difference. like you bought a whole new door. nice job!
  6. Dkhenry
    Atlanta
    Thanks, I'm going to finish sometime this week. I have to find the rear door piece now that I ruined mine trying the torch treatment.
  7. 4ctNduction
    T-E-X-A-S
    if you are careful you can also sweat it out with a heat gun. done it on several jeeps when the fenders fade. but the pics look great with what you have already done
  8. Dkhenry
    Atlanta
    I tried the heat gun and I couldn't get a uniform coverage, it would always have streaks in it. Maybe it was just me, or the color or the wide flat surface but I didn't have any Luck but thanks
  9. forduke
    forduke Member
    GA
    Does anyone know how long this product will last? I'm planning to use it on my faded exterior pieces.
  10. 4ctNduction
    T-E-X-A-S
    im curious is he did the rest of the vehicle. that one spot came out good
