Project drift cart
Discussion in 'Under Construction' started by TxFx04, Jun 26, 2013.
  1. Roush PSD Interceptor
    Yeah that's exactly what we want. Where we ride the dirt is real loose. Had that one wheel throwing dirt over our heads and boggin down ...in dry dirt lol. My fourwheeler has a rear diff instead of chain. Would be nice to find a full engine/rear axle. A reverse gear would be nice
  3. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    no reverse needed, just pick up the front end and turn it around, and as for suspension, find a couple of trashed mountain bike that has the suspension below the seat and take those off and mount them to the front. For the rear, I know it might sound stupid but go to a junk yard find a 2 bottom leaf springs take them off and have them cut in 4th's or 3rd's and get them clamped together and find a way to mount them to the back and still have it chain driven
    If we did any kind of suspension In the back we'd have to extended the frame and the chain. It already fits in the back of the truck perfectly. No need for a limo cart lol
  5. Ak 08 stx
    North Pole, ALASKA
    you wouldn't have to extend it at all, all you need is to drop the axle weld up some extra support mount the rear suspension and extend the chain, that all
  6. TxFx04
    Yes Carl. The motor is right over the drive gear. If the suspension were to compress the chain would fall off lol. The sprocket would have to be the pivot point of the suspension just like on a chain driven race quad or dirt bike
  7. cowboy
    you just need a chain tensioner pulley to keep the slack out of it.
  8. 01f1502wd
    better than not having any ideas at all.... :insane:
    and I meant put the engine in the middle of the back of the cart so the shafts are the same length, like FWD cars a shorter shaft will pull harder and faster...not good for a drift car. not like an italian sportscar with the engine in the middle of the cart.
  9. AKBray907
    Are you primarily talking for offroad drifting or on road?
  10. AKBray907
    Gt40 ain't Italian :poker:
