Transmission noise- w/ video
Discussion in 'Engine & Performance' started by Masonsf150, Jul 9, 2013.
  1. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    It was 1/2 and I tried but I couldn't get a wrench in there because of the exhaust and I didn't have the right exstentions but I did take the peep hole cover out and moved the flex plate around and that didn't seem to make the noise. It wasn't loose and seemed fine
  2. AKBray907
    Mason slide under the truck with your face near the oil pan, looking back towards the tranny you'll see a part of the tranny that drops lower than the engine block, there is two bolts there holding a plate onto the trans, pop those out and you can see the flywheel. I'm thinking it sounds like a flywheel problem an not internal tranny because typicall internal stuff has a deeper tone to it, that sounds like something more externalish
  3. AKBray907
    Oh an use an open end wrench to undo it, it's easiest way around the exhaust. But once it's off, turn the engine over by hand, looks for cracks or wear and also make sure the tc bolts are tight
  4. Masonsf150
    St.louis
    Alright, I'll find a box end and pop the cover off. I see what you mean now. Would I still have to pull the trans to repair the tc or flex plate?
  5. AKBray907
    Unfortunately yes, but just see how it looks first. Look for cracks, wear, shavings, loose tc bolts, anything
  6. Masonsf150
    St.louis
    Well I don't know this is weird but the transmission hardly make the noise anymore and it seems fine but every once in a while od will kick in at a low speed and it shakes the truck since its low rpm but I don't know. This weird to any if you?
  7. Masonsf150
    St.louis
    Correction- aode transmission. What I've read is maybe a oil pump going bad. Any thoughts
  8. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    Once again it's not an aode
    Sent from my iPhone 4 using Ford Power
  9. Masonsf150
    St.louis
    Can you help me identify it? I looked up the pan bolt pattern an it is of a aod and not a e4od. Maybe just a standard aod?
  10. Masonsf150
    St.louis
    I'm so confused on the identification.
