Transmission noise- w/ video
Discussion in 'Engine & Performance' started by Masonsf150, Jul 9, 2013.
  1. cowboy
    4.9L v6 is a c6 transmission
    5.0L v8 is a 4R70W
    5.8L v8 is a E4OD
  2. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    I have a 5.0 2wd
  3. Masonsf150
    St.louis
    And the noise is back for now. I will research problems that sound the same with the 4r70w. Any other ideas
  4. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    Yep 4R70W, electronically controlled AOD with some planetary gear upgrades. Still expensive to rebuild..
    Sent from my iPhone 4 using Ford Power
  5. Masonsf150
    St.louis
    Ok. From what I read the oil pump causes the noise because its not working right, so should I just replace pump or rebuild whole trans?
  6. nflfreak43
    Smyrna, TN
    Get a second opinion on it from someone that does it everyday..
    Take it to a trans shop for there opinion. But a REPUTABLE ONE!!!.. May cost ya 100 bucks on the front end but may save you money in the end...
  7. Masonsf150
    St.louis
    What do you mean? Have a inspection?
  8. cowboy
    yes by a transmission shop.
    Go redbirds!
  9. Masonsf150
    St.louis
    Will they have to pull the trans.
  10. cowboy
    :shrug: idk you will have to talk to them.
