davbell22602: 67 F100
Discussion in 'Under Construction' started by davbell22602, Aug 9, 2013.
  1. davbell22602
    davbell22602 67-79 Ford Trucks #1
    Bunker Hill, WV
    Got impatient so decided to go ahead and apply the purple power deruster on back half of the frame.
    Sent from my XT881 using Tapatalk 2
    Is purple power phosphate based?
    I kept googling the Purple Power website
    and the product list wouldn't redirect my webpage.
  3. davbell22602
    Bunker Hill, WV
    Not sure. Its phosrphori acid cas #7664-38-2
    They have msds sheet under the product at www.clean-rite.com
    Thanks David.
  5. davbell22602
    Bunker Hill, WV
    Did some primer today on the frame.
  6. davbell22602
    Bunker Hill, WV
    Not very good outcome in having the welder repair 4 rotted holes. He was only able to repair 3 out of 4 holes. Passenger side front cab mount frame wing needs replaced on frame. Welder used 11 gauge steel to weld plates under each hole. The 4th weld was just burning the wing even after turning the heat down on his welder. Someone here local told me to try Dessert Valley Auto Parts in AZ to see if they had a usable replacement wing.
  7. davbell22602
    Bunker Hill, WV
    Here's pics
  8. AKBray907
    No offense but that welder screwed you over, that is some novice looking work. It explains why he couldn't repair the one wing, find someone who knows what they're doing an they could easily remedy that
  9. TxFx04
    :okay2:
  10. Darth Bama
    Damn Dylan, you should be ashamed.
    :jester:
