Rust repair- need help
Discussion in 'General Discussions' started by Masonsf150, Jul 15, 2013.
  1. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    Thanks
  2. Masonsf150
    St.louis
    Front driver side fender patch is finished with bondo. I have some body work on it to smooth it out then I'll put some spotting putty on and get it ready for paint.
    The bed patch needs about 2-3 more coats of bondo then finishing work.
    Paint I'm open to suggestions. I also have a spot on the from fender on top where the clear coat is peeling off an was wondering if I could sand it down and get the flaking off clear off and reclear that area. My grandpa had that ideA.
  3. DestinationFX4
    Bedline the whole thing...it will look awesome
  4. Masonsf150
    St.louis
    Some say it will look cool and others say it won't. I'll try paint then of it looks bad ill bed liner
  5. Masonsf150
    St.louis
    Sand and primer then paint time
    Some more spotting putty and sanding then primer
    Paint will be on soon. Anyone know where to get automotive paint?
  6. Masonsf150
    St.louis
    Any body know how to fix wavy bondo? Should I jut fill and sand smooth or what? I can't seem to find the paint color in enough to paint what I need they are like 5oz scratch kits only.
  7. Masonsf150
    St.louis
    Well I just gotta keep spotting and working with it. I have everything about as good as it's gunna get.
  8. Masonsf150
    St.louis
    well I'm going to call some places and see of they have na or can mix it up. If that doesn't look good then i think I'm going with some black rattle cans and do a two tone. What do you think?
  9. AKBray907
    Filler is really meant to be used just as a skimmer and never really thicker than 1-2 dimes at most. It's wavy because the metal behind it got messed up. Try to fix the metal an then skim coat an then use a long block to start blocking it and that'll fix your issues
  10. Masonsf150
    St.louis
    That's what we started doing. And I learned tht I need to wait more for everything to dry hah.
