Got impatient so decided to go ahead and apply the purple power deruster on back half of the frame. Sent from my XT881 using Tapatalk 2
Is purple power phosphate based? I kept googling the Purple Power website and the product list wouldn't redirect my webpage.
Not sure. Its phosrphori acid cas #7664-38-2 They have msds sheet under the product at www.clean-rite.com Sent from my XT881 using Tapatalk 2
Not very good outcome in having the welder repair 4 rotted holes. He was only able to repair 3 out of 4 holes. Passenger side front cab mount frame wing needs replaced on frame. Welder used 11 gauge steel to weld plates under each hole. The 4th weld was just burning the wing even after turning the heat down on his welder. Someone here local told me to try Dessert Valley Auto Parts in AZ to see if they had a usable replacement wing.
No offense but that welder screwed you over, that is some novice looking work. It explains why he couldn't repair the one wing, find someone who knows what they're doing an they could easily remedy that
