Not build, but a mod thread.
Discussion in 'Under Construction' started by Bdons-SD, May 15, 2011.
  1. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    but your right turbo whistle FTMFW, we drive a excursion for the work truck at pogo mine and turbo whistle I love, I play with it most of the time when driving
  2. Bdons-SD
    I got my ATS housing and bd diesel billet wheel finished up today! Took me a good 8 hours total with a couple trips to the auto part store for some new bolts. The clamp on the up pipe was a SOB, that took me 2 hours last night ha ha. I pulled the whole turbo and the pedestal and replaced the upper and lower o rings, they were leaking pretty bad. Cleaned up what I could/felt like ha ha, and put her all back together this morning. NO MORE SURGE!! Ha ha and a nice little whistle
    Pics!
    Look at all that extra air flow I get!
    That's sexy
    sent from my igloo
  4. Bdons-SD
    Sounds as good as it looks ha ha
  5. Ak 08 stx
    North Pole, ALASKA
    love hearing a good whistle on a turbo
  6. Bdons-SD
    I need to get a good vid. My iPhone vid sucks, not even worth uploading ha ha.
  7. Bdons-SD
    Picked up an energy suspension poly sway bar and endlink bushing set. They sent me the kit for the 1 inch sway bar by mistake. But I had already "heat and beat" the tie rod type end link bushings out so now I'm sway bar less until the right kit comes in this week. i ordered It in red to match the boot on my rancho steering stabilizer. never going to see it, but what the hell ha ha. They're machine pressed in so it took a little heat. But once they were out and since I have the time now, I cleaned them all up and hit them with rust oleum spray on bed liner. I've never used it before so I thought it was a good time to experiment. I think I'll be using it more often.
    Having one of these is always handy ha ha.. I need a shop.. I acquired that hitch somewhere I can't remember, but it's solid instead of hollow square tubing. Makes an awesome anvil ha ha.
  8. 01f1502wd
    yyyyeeessssssss mmooooaarrr bedliner meow!
  9. Bdons-SD
    It turned out really nice, not cheap and flakey like I thought it would be. I going to buy a whole case! Ha ha
  10. 01f1502wd
    it does get expensive...but sooo worth it.
