Masonis1 95' F150 build- start to now
Discussion in 'General Truck Discussion for all Generations' started by Masonsf150, Sep 8, 2013.
  1. AKBray907
    Yea at the top end haha, that's what I'm saying. The h.o has smaller runners an will make more power than the truck intake mid to low rpm but at high rpm the truck intake is better. That's why people used them on the drag cars.
    Personally I'd go aftermarket for intake but if you're on a budget snag an explorer intake when you get the heads
  2. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    Hah it sure is a dd but getting on the highway or under a bridge you better know it that it's floored :) see 4g in a 302 and you're at 300, I'm wondering why not put that money into a 351 or 460
  3. AKBray907
    Because you'll have another several thousand for all the stuff for the swap
  4. Masonsf150
    St.louis
    Oh gotcha. What did you do with your tune in your truck
  5. Masonsf150
    St.louis
    How does this list sound for a 460 build and would y'all go efi or carb
  6. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    Currently I'm on a stock tune and fuel system.. Needs to be upgraded but it could survive as it sits.. Currently 4500 miles on it..
    Smokin' Tires with my 5.0 on Tapatalk
  7. AKBray907
    Pic shows up super blurry, can't read it mason
  8. Masonsf150
    St.louis
    Oh hah sorry. Ill copy what it says
    #4
    03-30-2008, 12:39 PM
    DJOHAGIN
    Senior Member
    400-425HP 460ci
    Intake System:
    750cfm Holley DP professionally calibrated for your application
    Edelbrock Performer Rpm Intake Manifold
    Cylinder Heads:
    D0VE heads with mild port job and chambers polished
    (315ish/180-ish cfm flow @.600)
    Intake valve size 2.08
    Exhaust valve size 1.65
    Stock rockers.
    Short Block:
    Comp Cam XE262H Hydraulic flat tappet cam or equivalent
    (Specs:262/270 adv., 218/[email protected], .513/.520, 110 LSA)
    Compression around 9.5:1
    Stock crank
    Stock rods with good bolts
    Standard volume oil pump
    Stock oil pan with windage tray
    Exhaust:
    1 7/8" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
    Summary:
    91-octane. Keep redline to 6000 rpm.
    425-450HP 460ci
    Intake System:
    Cylinder Heads:
    D0VE head with mild port job, chambers polished, and port match
    (315-ish/180-ish cfm @.600)
    Roller rockers.
    Short Block:
    Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
    Based on the Xtreme Energy Hydraulic Series
    Intake Lobe 5443 and Exhaust Lobe 5203
    (Specs:268/280 adv., 224/[email protected], .524/.544 lift, 110 LSA)
    Stock crank
    Exhaust:
    Summary:
    450-475HP 460ci
    Intake System:
    Cylinder Heads:
    D0VE head with mild port job, chambers polished and port match
    Roller rockers.
    Short Block:
    Comp Cam XE274H Hydraulic flat tappet cam or equivalent
    (Specs:274/286 adv., 230/[email protected], .562/.565, 110 LSA)
    Stock crank
    Eagle I-beam rods
    High volume oil pump
    Deepened oil pan with windage tray
    Exhaust:
    Summary:
    91-octane. Keep redline to 6500 rpm.
    475-500HP 460ci
    Intake System:
    750cfm Holley DP Carb professionally calibrated for your application
    Cylinder Heads:
    D0VE heads with larger valves, port job, chambers polished and port match
    (330-ish/190-ish cfm flow @.600)
    Intake valve size increased to 2.19
    Exhaust valve size increased to 1.76
    Roller rockers.
    Short Block:
    Compression at 9.8:1
    Stock crank
    Eagle I-beam rods
    Exhaust:
    1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
    Summary:
    91 octane. Keep redline to 6500 rpm.
    500-525HP 460ci
    Intake System:
    Cylinder Heads:
    TFS street heads with mild clean-up
    Roller rockers.
    Short Block:
    Compression around 10.0:1
    Stock crank
    Eagle I-beam rods
    Exhaust:
    Summary:
    Sorry it's so long. 450-525 is what I'm looking at, how true does this sound?
  9. nflfreak43
    Smyrna, TN
    Those numbers are at crank. So if you hit 450 your looking around 400 at wheels..
    But gaining ALOT of weight on nose of truck,
    Will be a torque monster, will break stock transmissions and rear ends..
    I feel like I've told you this before...
  10. Masonsf150
    St.louis
    Oops I forgot. Yeah I gotta see how much more a 460 weighs than a 302. I don't know why I want a 460 so bad.
