  1. TxFx04
    i give up on this build :jester: it's been too long
  2. 01f1502wd
    :lol: says the guy who needs 37s :gr_grin:
  3. 01f1502wd
    so I may have been slacking:
  4. 2wd supercrew mudder
    2wd supercrew mudder Full Access Member
    texas
    damn your truck as come along way from f150 forum i do have a question with your built tranny what programer do you have cause my tranny is a built 4r70w and it shifts prety hard with my programer edge evo on level two. so i leave it on stock. dose yours shifts hard as well ?
  5. 01f1502wd
    I have an Edge CS, I have messed with the trans shifting a little bit, my trans is built for ~600hp so with a stock engine that came from the factory with 230hp, it isnt going to have the performance/feel as a trans made to handle the 230hp, so it shifts harder (to protect the gears/clutches..etc), its sluggish but has a 3k stall which is awesome... On the tuner side of things I got a tuner to adjust my gear ratio and tire size, turning down the shift firmness only delays the shift and doesnt make it shift any less firm. When I speed up the shift it slams it when Im goin slow but WOT its smooth, and so quick it makes the serp belt chirp. On lvl 3 with 93oct....its a racecar on steriods
  6. MyFX4Project
    My serp belt squeeks when I get on mine at WOT. It only does it a few shift points but its still annoying lol
  7. TxFx04
    hey my mod list is getting shorter and shorter :hmm:
  8. 01f1502wd
    :head3: I really want to see it on 37s... Eventually I want to put 37s on my truck :Muahaha:
  9. 2wd supercrew mudder
    texas
    What tuner are you running my speedos way off with the edge cs. and do you a have 40r70w in yours. The guy who built mine said you can't build a performance tranny out of a 40r70w so he built it to the best parts they offer and I have to run syn fluid now
  10. TxFx04
    let me regear first NN
