Transmission noise- w/ video
Discussion in 'Engine & Performance' started by Masonsf150, Jul 9, 2013.
  1. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    Gotta sand and prime then ready for paint
    Some more spotting putty and then sand and prime then paint time
  2. Masonsf150
    St.louis
    The transmission is making a noise but its different now. It's a loud pop noise on acceleration from a dead stop.
    The output shaft also has some play that doesn't seem normal.
    Here's a video
    http://youtu.be/PbM0Zb-ussw
  3. AKBray907
    What's the tranny fluid look like? Take a pic of the rear of the tranny
  4. Masonsf150
    St.louis
    The rear of the transmission has always had a coat of oil on it since I know. It doesn't look like its leaking more.
  5. AKBray907
    Like check your dip stick an see how it looks, it's should be Ruby red, not brown or Metallicy or anything
  6. Masonsf150
    St.louis
    Ill check it tonight. I am scheduling a appointment at quality again because its free if it happens with in a month
  7. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    The output shaft on the 4r70w uses the driveshaft input as the bearing.. It sounds like the output seal is bad causing the leak an the clanking.
    Not to bad or expensive for them to replace if I'm correct..
    Smokin' Tires with my 5.0 on Tapatalk
  8. Masonsf150
    St.louis
    Awesome! That sounds like good news. Do you have to pull the transmission to get to them
  9. nflfreak43
    Smyrna, TN
    No.. They litterally just pull the driveshaft and the seal is right there where the driveshaft comes from the trans..
    But this is PURELY MY GUESS..
    It may be this, it may not be.. This is my best educated guess..
  10. Masonsf150
    St.louis
    I hope you're correct, sounds easy and cheap
