Masonis1 95' F150 build- start to now
Discussion in 'General Truck Discussion for all Generations' started by Masonsf150, Sep 8, 2013.
  1. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    Wow that's quick. Ya I see the fastest gen 1 lightning is a 408 turbo that runs 7
  2. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    Yep.. Greg's truck is now got a 408 twin turbo setup, should be on track lat late this season or next year..
    But his is the last true full on truck still
    Smokin' Tires with my 5.0 on Tapatalk
  3. Masonsf150
    St.louis
    Does he drive it on the street? That's cool
  4. nflfreak43
    Smyrna, TN
    He could have.. not now but when it's back up and running he's gonna roll on drag radials so he can drive it to the track and etc...
    It's down right now has been for 3 years to upgraded it.. Went from a 393 that was pieces together (back when they didn't make stroker kits, just cranks) to a 408 kit, ported his trick flow heads by Daryl white (very well known), upgraded from 57mm turbos to 74's, redoing the wiring harness to be nicer and sending ecu off for firmware upgrades..
  5. Masonsf150
    St.louis
    Projects seem to never end. My uncle and I are now starting to plan to drop the 350 back in the s10 to get it running again. Everything else is ready just gotta drop a 350 in with stock enternals and tune the truck then when that blows hopefully I will have the 350 with forged internals ready to be dropped it. It's a 350 with twin turbos but the turbos are small. Probably wont run more than 5psi. It's been sitting without a engine for about 4 years. Gotta clean out the cab and bed from being a transporter during his move and put the cam and heads onto the 350 bolt up trans and drop it in. Oh and make the double pumpers into blow throughs.
  6. Masonsf150
    St.louis
    Well got the truck painted. And now we gotta polish it. Doing that tomorrow.
  7. Masonsf150
    St.louis
    Polished it
  8. nflfreak43
    Smyrna, TN
    Looks good.. You can tell y'all didn't color fade but it looks great for a backyard job!
  9. Masonsf150
    St.louis
    Hah it's not too shabby
  10. BlackThundah
    Looks great to me. Very nice job man! :peace:
