No hi beams ):
Discussion in 'Audio & Electronics' started by TxFx04, Oct 10, 2013.
  1. Stangshcky12
    PA
    What kind of balasts are you using?
    The morimoto 3 five 35w I believe
  3. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    S**t brother, that looks all hacked up to f**k. Spend the extra money and get yourself a real plug-n-play kit.
    It's 3 simple wires cut. Did you even read the thread? Obviously I spent the money on true hid projectors to get rid of the hids and I'm Trying to fix the mistake I made when I got hids. I'll have to figure out which wire is which in the projector harness
  5. Roush PSD Interceptor
    Does your Morimoto look like this?
    I don't see a wiring connector for the HID bulb shield
    on this pic of Morimoto 3 five 35watt ballasts. Maybe yours is different.
    There should be a smaller 3rd or 4th wire connector coming
    out of the ballast that goes to the HID bulb
    if it is a "low and high" beam setup.
    If there are only two wires coming out of the HID bulb itself
    then they are "low beam" only, 3 or 4 wire HID bulbs are "high and low" beams.
    The two smaller wires are for the shield that lowers the plasma light output (low beam).
  6. Roush PSD Interceptor
    Copied this from the TRS site:
    7. Low beam or Bi-xenon Projectors: When choosing a bulb from TRS, it does not matter whether you are using low beam or bi-xenon projectors. Unlike halogen headlights, with bi-xenons, nothing happens to the bulb when the high beams are activated. It does not get any brighter or shift positions. Simply put: you don't need "low beam" or "bi-xenon" specific bulbs. Our S2K-R low beam projectors and FX-R bi-xenons both use "D2S" bulbs.
  7. 01f1502wd
    Rousch, I believre I had 2 wires I didnt use.. Since its an H1 bulb it fits many different vehicles using the hniversal h1. Then out of the harness is a plug that goes into the oe plug.
    Dylan it may be smart to go to oreillys and get a new plug so its not ghetto wired up
  8. TxFx04
    nothing is ghetto about it lol. i'm using butt connectors, not duct tape.
  9. Roush PSD Interceptor
    Can't be as bad as I've seen bandaids on car wiring before.
    Sent from my SPH-L720 using Tapatalk now Free
  10. 01f1502wd
    I guess...better than twisting em and leaving em
