Plug change successful still have one issue though :3
Discussion in 'Engine & Performance' started by 07Fx2, Oct 20, 2013.
  1. TFIDDLE
    Glad ya got it fixed
  2. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    Good stuff brother, good stuff. Don't forget to check your FPDM. That's one of the first things I checked and replaced on my truck. I don't know if you see lots of road salt or corrosion due to bad weather but the FPDM does cause issues when it starts to rot.
  3. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Where is that located at?
    i'll probably clean mine too after my swap this weekend
  5. ak_cowboy
    It's on the cross frame support under the bed, behind the spare tire.
  6. 07Fx2
    Oklahoma
    Thanks Will :beers:
  7. Tradesman
    Vancouver, BC
    Yeah my brother, the part cost me around $80 here so it should be much less for you. I went with a dealer part although you can get a FPDM that's aftermarket. Either way, if it shorts or dies you are stranded. All you need to do is drop the spare tire and it should be two 12mm bolts that hold it in place. It might be more difficult for you since your truck is slammed though. :)
    Do those things go bad over time, or just straight fail?
    sent from my igloo
