TxFx04's Build Thread
  1. AKBray907
    Not only that but e brake in snow, take a 1/2" PVC pipe 2" long, slit down the side, pull e brake release and then slide pipe over cable holding the release open. Then you have a drift truck in the snow haha, used to do that all the time
  2. 01f1502wd
    :hmm: [​IMG]
  3. TxFx04
    pulled the access plug in the rear and pulled these two pieces out, the E brake shoes and springs are all loose in there. still trying to get the rotor off hammers.. and bigger hammers..
  4. MyFX4Project
    Haha my ebrake cable came off somehow so I went to fix it and and ended up taking out all the shoes and such just because they were being difficult and were super worn. Never got around to replacing them lol
  5. AKBray907
    So you just don't have an e brake? Haha
  6. MyFX4Project
    Nope. Nothing inside my rear brakes for the ebrake. All the drums and springs were all rotted and not working so I just took em out. My driveway is steep and I never use my ebrake and i never have problems.
  7. 97madness
    I never thought i needed an ebrake.. until i lost my brakes on the way home from work. Not fun.
  8. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    I had the pin that holds the brake pedal assembly altogether break on me right after I finished swapping everything over on the fox...
    Thank god for the little bit of E brake I had and a 5 speed or I woulda been ******..
  9. TxFx04
    yeah i like to use my E brake when i park on an incline. got the rotor off and the E brake ripped out, everything was scraped to hell from bouncing around. rotors are pretty worn and pads have about 1/4 life left. adding a brake job to the list of shat to replace :jester:
    and a purdy picture of the truck on jackstand lol...
  10. AKBray907
    Yea good call, it's worth having an e brake and easier to replace everything at once
