$3500 oil change
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by joeygr8gt, Nov 16, 2013.
  1. joeygr8gt
    joeygr8gt Full Access Member
    Yah plugs r the only thing that scares me of they break ill have to get that tool to get then out
  2. MyFX4Project
    You have an 01 4.6 they shouldn't break.
  3. Bdons-SD
    You wot have a problem breaking any. I would expect to use your entire known vocabulary of curse words.. And some made up ones.
  4. joeygr8gt
    5.4 motor not 4.6. I'm havin a friend with a lightning help me he changes his plugs every yr. te fuel filter I changed in ten min with the tool and draining coolant now. Tyrant fluid looks fine on the dip stick so I'm leavin that
  5. MyFX4Project
    Ohh ok well still you won't break any off. Its the 3v 5.4 trucks that have issues with plugs and yours is a 2v. Good luck man.
  6. joeygr8gt
    Changed the plugs with a friend in one hour. None broke and went pretty well. Was easier than expected except for two. Only thig was four of the threads were soaked with oil but tips we're clean
  7. joeygr8gt
    Got my trailing arms off eBay from Pmc or whatever fabrication place for $180 shipped. BIGGEST PAIN IN THE ASS bolts and nuts were so rusted. The new ones were 1/4" longer than factory so I had to drill holes out. Then the driver side u can't get a wrench in cause if the gas tank and when u do u can't get the bolt out. God how I hate ford for cluttering everything. Up next is rear shocks. This time I'll pay someone to do it
  8. MyFX4Project
    Trailing arms???
    Rear shocks are simple man. Seriously simple. I can walk you through the steps but its literally nothing more than taking off bolts at either end and replacing haha
  9. joeygr8gt
    Trailing arms control arms same thing lol. Yah two bolts for the control arm weren't the easiest. Rusted like a mofo. Gota order shocks td
  10. iowaredneck
    You can change shocks trust me
