Oil on spark plug??
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by joeygr8gt, Nov 18, 2013.
  1. joeygr8gt
    joeygr8gt Full Access Member
    Did a plug change today and 4/8 plugs had oil on the threads but not the tip. Two were soaked. Is that a valve cover leak?
    Could be leaking.
    Was it wet from oil on the top of the head?
    I've seen oil weeping onto the top of the head
    from the valve cover gaskets on my
    mother-in-law's 4.6 Crown Vic.
  3. AKBray907
    Yup if it's oil from the top it's most likely a valve cover gasket or a cracked valve cover
  4. joeygr8gt
    Not gona cause a big problem right. Too cold to pull heads off do ill wait a little
  5. AKBray907
    Depending where it gets it could cause a misfire. You dont need to pull the heads just valve cover to replace the valve cover gasket
  6. iowaredneck
    ^what he said. If you start getting a misfirebyou will know why. Juat keep an eye on it
  7. joeygr8gt
    i meant the valve cover not the heads my bad
    thanks guys
  8. AKBray907
    Figured you did but just making sure :peace:
