04-08: How's Your Truck Holding Up?
Discussion in 'General Discussions' started by ak_cowboy, Jan 23, 2014.
Problems
  1. Engine
    1 vote(s)
    50.0%
  2. Transmission
    2 vote(s)
    100.0%
  3. Body
    0 vote(s)
    0.0%
  4. Electrical
    0 vote(s)
    0.0%
  5. Love the Truck
    2 vote(s)
    100.0%
  6. Hate the Truck
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. ak_cowboy
    List up the troubles with your trucks!
    Year:
    Model info:
    Mileage:
    Repairs:
    EX:
    2007 F150
    5.4 XLT 4x4
    105,***mi
    New Transmission @56k
    Power Steering Pump (my fault) @100k
    Spark Plugs @98k (none broke)
    #8 COP 90k
    Belt Tensioner Pulley @ 88k
  2. MyFX4Project
    Haha are we devoting a few pages for Dylan's truck :jester:
    :jester: Just adding posts :lol2:
  4. iowaredneck
    We would have to close the thread. It would be too full with his one looooooong post.
  5. TxFx04
    I was just about to say!! Hahah :jester: but I'll play along
    2004 F150 fx4(5.4)
    127k miles
    Spark plugs changed at 119k miles. 3 unbroken, 4 broken, one rounded off at the head of the plug(recently swapped)
    Misfires left and right,truck bucks like a bronco. need to start swapping COP's out. Throwing codes
    Strange unidentified rattled upon start up
    Transmission still shifts smooth surprisingly
    Cam phaser tick
    Vct's replaced
    Timing chain tensioner tick
    Throttle actuator code P2106 frequently(erase code on edge and restart)
    Replaced ball joints, tierods. Sway bar end links and uppers once, lowers need to be replaced again(thanks to lift)
    Cv axles still in good condition(knock on wood)
    3.55 gears suck
    Diff fluids replaced, front took on water, milky white fluid
    Friction modifier fixed clutch pack shutter in rear end
    Rear sliding power window rattles
    Dash rattles
    Window assemblies in the doors rattle
    Had to replace window regulator/assembly after it failed and dropped my window(passenger front)
    Rear U joint and yoke replaced (after driveshaft nearly snapped off, again thanks to lift)
    Hub assembly replaced after wheel bearing exploded(thanks to 35's)
    Drivers side E brake assembly failed and imploded inside, passenger side sounds like its doing the same(thanks to .... :think: )
    AND I STILL WOULDN'T TRADE IT FOR A CHEVY!!!!
    But I'll report back in a week with more problems :)
  6. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    08 stx
    4.6l auto trans
    57,400 miles
    havnt replaced nothing yet
    91 f150 xlt lariat
    5.0l auto trans
    127,5xx
    replaced 7 u-joints, 2 for the front driveshaft back and front, 5 for the main driveshaft 4 for the rear and 1 for the front
    oil pump (summer project)
  7. cowboy
    2004 F-150 FX4
    ~154,000 miles
    4 wheel bearings replace 2 on each side (1 was manufacture error)
    Driver side CV axle replaced
    Rebuilt transmission @~130,000 probably my own fault. Eclip for overdrive broken somewhere around 98,000 and never replaced it and chewed up the entire case.
    IWE solonoids were replaced when I first bought it for free @76,000
    Other than that it's been normal repairs, brakes, thermostat 2x, fuel filter, belt
    replaced the spark plugs @130,000 I believe 6 out of 8 broke.
    110k my rear Ujoint started squeaking
  9. ak_cowboy
    130k
    Lower Balljoints need replaced after the last 100k miles, Factory shocks are blown, UCA boots are opened cuz of the 2.5" level.
  10. Bee89
    Bee89 Super Moderator
    Miami, Florida
    2008 fx2
    ~135,000 mi
    sway bar links recently replaced, which i assume would fall under regular maintenance.
    Spark plug adventure coming very soon so that may bring some issues. Knock on wood i have been very fortunate to this point.
