Here we go
Discussion in 'Engine & Performance' started by AKBray907, Feb 2, 2014.
  1. AKBray907
    :jester:
    I have a set of 01 pi heads time serted and valve covers ill sell you to bump up the power on that baby
  2. MyFX4Project
    Damn dude. That looks great. I think im going to paint everything on mine black with silver/chrome accents. I dropped mine off at the machine shop last week and they still arent finished but its getting the same stuff done.
    You keep everything on the rotating assembly stock?
  3. AKBray907
    Thanks man, yea basically stock, better then stock parts but not like forged or anything, should work great for how I use the truck.
  4. AKBray907
  5. BlackThundah
    wow that looks sick dude.
  6. MyFX4Project
    Are you reusing all your pulleys, timing chains, guides, tensioners, etc.
    Im putting new everything on my engine so I was curious if you did order new parts, where from? Looking for good deals here because I know youre using quality parts lol
  7. AKBray907
    I got a new water pump, timing chains and guides and tensioners, new cam gears an spacers ( just cause I needed them for the head swap) and new pulleys, I'm using a mix between motorcraft parts and cloyes along with trick flow parts. I've never had any issues with cloyes parts along with the others so feel very confident in them but also it's hard to beat motorcraft.
    My pulley tensioner was fine so no need to replace
  8. AKBray907
    so was sent the wrong cam bolts, anyways still made some work so I could set the timing and get the chains on. Waiting on some more parts to come for both engine and tranny and then install.
  9. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    them short tube headers
  10. AKBray907
    Oh yea.... Truck is back together and I'm about to cross ino canada on my way to Alaska haha. Drives amazing. 4.56 gears make a huge difference and the trans is amazing. Shifts are perfect even pulling a 8200lb trailer
