Masonis1 95' F150 build- start to now
Discussion in 'General Truck Discussion for all Generations' started by Masonsf150, Sep 8, 2013.
  1. Roush PSD Interceptor
    Electrical problems are hard to diagnose.
  2. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    I checked my codes today-
    311- thermactor air system problem- no operation during engine run self test
    411- cannot control rpm during engine run self test low rpm check
    412- cannot control rpm during engine run rend check high rpm check
    538- insufficient rpm change during dynamic response test (engine run self test) or, invalid cylinder balance test- throttle position movement or, invalid cylinder balance test- cylinder identification problems
    565- canister purge solenoid circuit failure
    Can anyone help me out with these?
  3. Masonsf150
    St.louis
    Looking for a taillight. Someone hit it today in front of my house. ImageUploadedByTapatalk1400624268.478792.jpg
  4. 4ctNduction
    T-E-X-A-S
    it does suck that they hit the tail light, but on the good side...atleast it didn't hit the body
  5. Masonsf150
    St.louis
    Yea gotta look positive
  6. BlackThundah
    I'd check ebay or rock auto for a new taillight. I normally go to ebay for stuff like that.
  7. Masonsf150
    St.louis
    Got new tails in- went to charge my ac today and the compressor was locked up... Anyone know anywhere cheaper than partsgeek? 138 shipped is what I have found
  8. Masonsf150
    St.louis
    Ordered new compressor- let's hope that's it
  9. Roush PSD Interceptor
    Good idea to change the dryer / receiver
    and clean / inspect the orifice tube while
    you have the AC system apart.
    Pull a vacuum on the system before
    installing the freon.
  10. Masonsf150
    St.louis
    Alright thanks for the info. Hopefully it gets in soon- getting hot out
