It's morning I went to getting the truck pulled the door handle and the lever never retracted. With the doors unlocked the door doesn't stay closed and I can't open the driver side door. Is there something that I have to just I just or do I need a new door handle. It has the keyless entry pass code on it as well Sent from my iPhone using Tapatalk
Did you happen to press the little latch on the inside of the door actually latches it shut? I was messing with my door handles and accidently pressed that and then couldnt get the door to shut. Had to pull the handle up and press the latch back down to get it to shut. The inside of the handles and how they work is relatively simple if you just pop the door panel off and look at it that way.
I auto started my car this morning went to use the keyless entry code open the door and the latch stayed up Sent from my iPhone using Tapatalk
