The audi build
Discussion in 'Other Vehicles' started by AKBray907, Sep 5, 2014.
  1. MyFX4Project
    What did you use to get the engine that clean?
  2. AKBray907
    Simple green, spray and let it sit for a little while and then hose off and air dry. Do it a couple times
  3. Roush PSD Interceptor
    DSS does the Audi,
    let the awesomeness begin.
  4. 97madness
    Send it to me when you're done, mk? Lol
  5. MyFX4Project
    Ive used that before on my engine and it never comes out that good lol guess ill have to try it again.
  6. Darth Bama
    Simple Green works wonders when you let it sit long enough. I do my engine about 3 times a year. The old girl still looks new because of it.
  7. AKBray907
    Only was able to work on it for 3 hrs tonight, so replaced the timing belt, all the timing pulleys, new water pump, new thermostat, new serpentine belt and idler pulley also changed the oil. Got the front sorta set on. After class tomorow gonna drop the trans pan an change the filter and fluid. And redo the trans lines that got cut.
  8. Pity7700
    cant wait to see this project!
    that motor is pretty damn clean!
  9. AKBray907
    So carfax had showed that this car had 49 service records and said it was worth 1600 above book value because of that, we'll after pulling the tires and looking at the susp it definitely looks like it had been well cared for. No movement in any ball joints, shocks look new, new brakes looks great
  10. AKBray907
    So i Got it running already , good oil pressure, good temps. Idles good, still missing an intercooler and running out old gas. Revved it a little and it actually sounds pretty throaty for a little sixxer
    Here's a video of the idle
    01 audi a6 2.7: YouTube
