Led light conversion
Discussion in 'General Discussions' started by ccatt93, May 4, 2015.
  1. ccatt93
    ccatt93 Junior Member
    Wisconsin
    Hey guys I'm trying to convert everything over to led lights I have my dome lights and my marker lights done so far I was wondering if anyone knew what size bulbs to all get for example
    Reverse lights
    Cargo lights
    The small lights on the inside of the door when you open the door
    The cruise control light bulb size
    Dash lights
    Glove box light
    Ash tray light
    And if anyone can think of any others
    Also when I do my dash lights I was wondering if there was any way to make the needles white I was thinking blue with white needles
    Thanks guys!
    Check out vleds or superbrightleds .com. They've got tools that list out all the different bulbs that will fit your truck.
  3. ccatt93
    Wisconsin
    I checked superbrightleds and the said that for my courtesy light (I assume the one by the side of the door) that it was a round bulb but it's not it looks closer to a 194 style so I'm not sure
    Maybe they are talking about the
    festoon style bulb that may
    be in the overhead light.
  5. ccatt93
    Wisconsin
    Yeah it is in the over head light but I got it figured out now I just need to figure out what to get for dash lights and if I can get white needles
  6. FofTworide
    FofTworide Full Access Member
    GA
    Seen this from the other board I'm on:
    97-03 Ford F150 Light Bulb Fitment Application List:
    Parking light uses 3157A bulb.
    Tail light uses 3157 (red)bulb.
    High mount stop light uses 912 bulb.
    License plate uses 194 bulb.
    Back up light uses 3156 bulb.
    Ash tray uses 37 bulb.
    Dome light uses 912 bulb.
    Dome light uses 578(festoon) bulb.
    Step/Courtesy light uses 168 bulb.
    Under hood light uses 912 bulb.
    You should most of the parts/bulbs at SuperBrightLeds.com and other miscellaneous like here Misc. LEDs & Accessories | 4WheelOnline.com
  7. Shaggy
    Arizona
    You get it figured out?
  8. ccatt93
    Wisconsin
    Still waiting on the cruise control lights
  9. ccatt93
    Wisconsin
    And if I can get white needles
  10. Shaggy
    Arizona
    So you got everything else on except those 2 things?
