here she is guys!
Discussion in '12th Generation F-Series : 2009 - 2014' started by Pity7700, Dec 15, 2014.
  1. Pity7700
    I just want to protect it, don't want it to rust out like my 02 did.
    pulled the steps off, I have some bubbling in the paint but no rust. going to pop the bubbles, let the water out and let it dry and then going to hit it with some por-15 before I put the liner on.
    I liked the look of the liner on my 02 but no one really sees it unless theyre looking under the truck.
  2. Pity7700
    Took a couple pics with the steps off, looks clean.
  3. MyFX4Project
    Ohh ok. I didn't realize you had liner on the 02. You are doing the actual rocker panel, not 6 inches up the side of the truck. That'll be good. My subercrew is pretty far gone, just not as many holes as my scab has lol
  4. Pity7700
    noooo! lol my doors are good, just the rockers. im doing the back side underneath the truck as well, I might go up the side of the rockers too.
    Im probably going to line the inside bottom lip of the doors though.
  5. TxFx04
    I used to have a red extended cab :(
  6. Pity7700
    hahaha I love extended cabs!
    fender flares should be here tomorrow. theyre coming from Ohio.
  7. Pity7700
    Flares came!
    Didn't realize that my 2010 has no bolts in the fender from the factory so now I have to drill some holes in it to install the flares.
    The flares came with double sided tape already attached to the flares and a bag of self tapping screws, won't be using those.
    Going to get some small trim bolts and U clips for the fender lip. I will also be painting the inside of the fender after I drill holes. I'll probably put some por-15 around the holes and then I might roll bed liner on the inside of the whole fender.
    I don't want any rust!
  8. MyFX4Project
    Looks good. You need to open up your headlights and paint them like Dylan did
  9. Pity7700
    I honestly have no clue how to do that lol.
    trying to get these flares drilled and temporarily mounted on the truck tonight so I can paint the wheel well tomorrow. ill throw a picture up of one of them mounted in a second.
  10. Pity7700
    Just need to drill the fender. Hopefully I don't mess it up lol
