My new truck!
Discussion in 'General Discussions' started by TxFx04, Jan 23, 2015.
  1. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    Leave it to puppy boner to put a dick on his truck the first chance he gets....
    Sent from my SM-N900P using Tapatalk
    Yeah even though it worked perfectly on the 04 for whatever reason. Oh well, my buddy wired everything up pretty legit. Just gotta mount the switch a little better
  3. TxFx04
    Just for you bud ;)
  4. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    As always you're the electronics expert. I'm sure you're right, the draw from a trigger wire wouldn't be enough to kill the reverse circuit. However, most people I know don't run reverse pods off of a relay, they tap straight into the reverse harness. I personally did it that way on two different GMs with no long term issues.
    It doesn't take much to kill the reverse lights on the 09+ Fords though. This little guy sure does it.
  5. Roush PSD Interceptor
    I'd say a Hella relay trigger to the reverse lamp wire and
    contact 30 of the relay to fused 12 volt battery source
    in the trailer harness or if that isn't available
    run a fused power wire back there for aux.
    lighting.
    The switch gives on/off capability even
    without reverse gear engagement.
    There we go again, most don't want the cost or labor involved
    with running extra wires/relay/fuse.
    If it's electrical
    we'll just leave all those wires alone.
    They aren't
    paying someone else at a hole in the wall
    stereo chop shop to mess it up with 110
    volt twist nuts and 3 rolls of cheap black tape.
  6. TxFx04
    sometimes i wonder if you take too many medications :think:
  7. TxFx04
  8. Roush PSD Interceptor
    Way better light output than those tiny stock back up lamps.
  9. TxFx04
    I'd say so, now I don't have to use my brake lights for output when I back up
  10. Roush PSD Interceptor
    BTW what kine is the kolf gart?
