Manifold Bolts
Discussion in 'F-250 and F-350 General Tech and Info' started by nast70, Aug 7, 2015.
  1. nast70
    nast70 Junior Member
    Getting close to the time to get all the manifold bolts replaced on my 09 f250. Ive been told to budget around $2500 for this project. That seems high to me, even for these little monsters. Anyone else care to share their own experience?
  2. Bdons-SD
    What motor do you have? Gasser? 5.4 is a b-itch because of access and broken manifold studs, I got a quote for $475 from my regular guy to do ONE side on my wife's 5.4 expedition. That was just labor since I bought the parts thinking I was going to do it. The motor mounts need to be unbolted and the motor needs to jacked up about 3 in, and the access is still terrible, took me 2 hours to get that spot and I gave up and put back together. $2500 seems a bit high, I would say 1200-1500 maybe for both sides depending on your motor, v 10 might be more. Also if you do have a 5.4 it would be a good idea to replace the manifolds of you're paying for labor already. The 5.4 manifolds have a tendency to warp and leak a bit.
  3. nast70
    Its a 5.4. Didn't think about the manifolds themselves. I will look into that as well.
  4. Bdons-SD
    Yeah, the reason it's such a pain on the 150s and expeditions is the coil/ strut mount is right smack in the way. The 250 might be different. The 3v 5.4 manifold, studs, and gaskets are around $50 per side on Summitracing.com for oem.
