p0401 code
Discussion in 'Engine & Performance' started by fordf150, Sep 8, 2015.
  1. fordf150
    fordf150 Junior Member
    plattsburgh
    I have a egr flow problem I have replaced everything and still get the po401 code. I looked how to test my dpfe and what I read and see is that the voltage is suppose to rise but it drops on mine dose that mean its bad everything else works as it should. Its my third dpfe the the voltage has drop in stead of raised can all three be bad.
    Have you checked the dpfe sensor tubes for cracks
    or a plugged with carbon condition?
  3. fordf150
    plattsburgh
    Yes I've checked all that and its was all good.
  4. Darth Bama
    I had two different sensors come out the box bad. Highly unlikely, but not impossible.
    Sent from my iPhone 6 using Tapatalk
  5. fordf150
    plattsburgh
    Update I found a crack in the steal tube down by the exhaust manafold is that my problem.
  6. Roush PSD Interceptor
    JB Weld
