New member, 01 expedition from Canada
Discussion in 'Introduction' started by northernexo, Oct 19, 2015.
  1. northernexo
    northernexo Junior Member
    CA
    Well I managed to find a cargo net that will work in my expedition, and its a 2001-2007 Toyota Sequoia cargo net that fits perfectly.
    I ordered one from Toyota today and managed to swing a discount because I have a buddy that works there.
    I've seen them on eBay for cheap but quality is always questionable with easily manufactured items like a cargo net, side by side it might be hard to tell the difference its usually after some usage where you find what's good and what's not.
    Sent from my SGH-I337M using Tapatalk
  2. northernexo
    CA
    Picked up some slime green LEDs today to match the oem green tint on the gauge faces, I'm curious to see how they will look. I'll have time tonight to put them in.[​IMG]
  3. Roush PSD Interceptor
    Slick Sick slime green.
    Post them pics when
    Installed brother.
    :cheers2:
  4. northernexo
    CA
    What a nightmare, my cluster had twist sockets with bulbs that aren't removable, so the 168s wouldn't work with my cluster.
    Not to be deterred I went ahead and pulled the 168s from their bases and soldered then directly to the cluster. I will be wrapping it all up tonight, my only spare time is when I should be sleeping, I stayed up late last night messing with the cluster so I'm exhausted at this point.
    Also, my Toyota Sequoia cargo net came in today at Toyota, and it fits the expedition like it was made for it.[​IMG][​IMG][​IMG][​IMG]
  5. northernexo
    CA
    [​IMG][​IMG]
    The pics don't do it justice but the lights are very nice and more pleasant to look at when driving. If I knew it was going to be this difficult I wouldn't have touched the cluster but at least it's over with.
    If my expeditions cluster came with the twist sockets with removable bulb it would have been a plug and play affair but this was rediculous, because the LEDs are much bigger than the regular bulbs there was so much back and forth playing to do to get the bulbs through all the holes and then applying enough force to get the needles for the gauges to push through the motherboard but not so much force as to break the soldered points.
  6. ak_cowboy
    IT looks really good. glad you got them all to work.
  7. northernexo
    CA
    Thank you very much, it was a huge pita to do it.
  8. FofTworide
    FofTworide Full Access Member
    GA
    All seems going great buddy, nice truck for a 2001! I like the cargo net.
  9. northernexo
    CA
    Thank u very much! The cargo net is very handy, the expedition is nothing crazy but I try to make it as presentable as possible.
  10. jparks54
    jparks54 Full Access Member
    Canton, Tx
    Looks good and welcome
    Sent from my SM-G900P using Tapatalk
