Transmission swap help
Discussion in 'Engine & Performance' started by 01f150red, Sep 15, 2015.
  1. 01f150red
    01f150red Junior Member
    monterose,Ill
    I have a 98 4r70w will it work on a 01 with the 4r70w both are 4x4?? Anything different or mods that will have to be done??
  2. C Denny Run*
    C Denny Run* Full Access Member
    Bellingham WA
    Same engine? As long as the length didn't change, connectors are the same, and hole patterns match up, I see no reason why it wouldn't work. I've been wrong in the past though:crazy:
    It'll work fine. They didn't really mess with the transmissions until 09 when the new 6-speed came out. I would do a rebuild with upgraded valve body on the replacement before installation as well.
  4. 52 Ford
    52 Ford Junior Member
    US
    I though some of the wiring changed around '99. I could be wrong, but I think I remember reading that somewhere when I did an engine swap on mine. Something about the shape of some of the connectors on the harness.
    Edit: OOPS. Just realized how old the thread is.
