New truck parts just arrived !
Discussion in 'Street Scene' started by 4ctNduction, Jun 2, 2015.
  1. 4ctNduction
    T-E-X-A-S
    Do you have a close up of the front suspension and bags? I'm trying to figure out ratios for something.
  3. 4ctNduction
    T-E-X-A-S
    sorry for the late response, yea i will take a pic here in a second.
  4. 4ctNduction
    T-E-X-A-S
    well....first problem. on the way to work this morning i heard the reciever hitch hit the ground so i knew the truck was too low, so i aired it up....then a couple seconds later it hit again. thats when i learned there was a leak somewhere in the rear. needless to say the truck came into the shop on a wrecker and now i get to figure out what the hell is wrong.
  5. Darth Bama
    Ugh, see that's what always scared me about bagging my truck. I don't want to have to bother with anything, regardless of what it is. Is there a control to stop it from completely laying out if the air leaks out completely? That said, fugger, you're gonna make me end up spending money on Ole Blue! I wants the moar low!
    Sent from my iPhone 6 using Tapatalk
  6. Roush PSD Interceptor
    Titanium bumper hitch?
  7. iowaredneck
    Air ride equals problems. Had an expy with air ride. Never again
    That sucks.
    What compressors are you running?
  9. 4ctNduction
    T-E-X-A-S
    i have dual viair 480s on it right now.
    so what ended up happening is the back drivers side bag got a puncture in it. the bag must have shifted over to the side towards the frame and there was a screw head right there and it wore through the bag. i just got the new bag right now and you BETTER BELIEVE we are going to go over each bag cause i refuse to have that happen again. luckily i was off of the highway when the rear finally wet out cause there is no moving once its laid out. when it got to the shop we got a jack under it and lifted the bed up and actually put a block of wood inbetween the axle and the step notch and it allowed me to move it around
  10. Roush PSD Interceptor
    Twas good you weren't on the freeway when it deflated.
