Front end clunking...
Discussion in 'General Discussions' started by TxFx04, Dec 13, 2015.
  1. ak_cowboy
    How are your tie-rods? Everything got tightened to spec after the lift? with a torque wrench?
    Tie rods are new, they came with the lift. Everything was torqued
  3. AKBray907
    cvs can do what youre talking about when they go bad. they can also get a little vibration feeling to it also.
    I was worried the cv's were binding with the added lift.. They're at a pretty ify angle
    How do I check if they're for sure bad? Before I spend $180 on new axles
  5. TxFx04
    Got everything torn apart... I can't figure it out. Hubs don't have any movement. Lower ball joints don't have movement. I'm not really sure how to test is a cv axle is bad or not
  6. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    Sway bar links/bushings all good?
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  7. Roush PSD Interceptor
    Dylan said they were new Moog links/bushings.
    I'm still thinking Dylan could have checked the CVs with the tires mounted on it.
    Maybe it's more of a mystery sound and nothing is loose or breaking???
  8. TxFx04
    Turns out the upper A arms where fairly loose where they mount to the frame. I tightened them as tight as I could. It fixed 75% of the clunking. Something Still makes noise
  9. ak_cowboy
    Are your shocks tightened down? My passenger side loosened up after a couple hundred miles
  10. TxFx04
    I put my gopro underneath and drove around to see if there was anything abnormal looking.. Everything looks fine. The only thing i can possibly think of is like Will said. maybe the top nut on my bilsteins came loose or aren't tight enough? I might pull the spacer off tomorrow and see if they are tight or not. If i still can't find anything i'm taking it to the shop that installed my lift..this is ridiculous. It's gotten to the point where i hate driving my truck now because of all the clunking. :Grenade:
