  1. ak_cowboy
    Pretty crisp. slightly vertical to me tho :jester:
  2. 2thousand5four
    Virginia
    Lol and yeah it's not a bad shield. All the holes didn't line up perfect but that's not a big deal, nothing a quick grind with the dremal couldn't fix. I mostly finished one the cut off shields. I still got to tweak it a little to make it perfectly flat but it's not to bad. [​IMG]
    So you're getting rid of the stepdown?
  4. 2thousand5four
    Virginia
    Yep, no reason to have a step on fog projectors. I'm trying to get them like this [​IMG] those are ford fusion fogs
  5. Roush PSD Interceptor
    Clean cut off on that one.
    Seriously looking at those 7.0 with 5500K bulbs.
  6. 2thousand5four
    Virginia
    You should definitely get some. The only downside I see about them is that they use H1 bulbs and there is no OEM h1 hid bulb so your bulbs won't be DOT approved, and sometimes you have to shim them to get the Hotspot right. Other than that they look like amazing projectors. TRS just released there CAD drawing of the d2s 4.0s. If I knew they were coming out I would have waited for them. [​IMG]
  7. Roush PSD Interceptor
    LEOs here love to write tickets on
    any and everything non-stock.
    Would be better if I bought something
    bi-xenon and DOT.
    Mine look basically stock, and function better than most lol. I think the cops are going to have a hard time proving a projector retro is illegal, but I'd love for them to pull over all those ricers with the 8000k bulbs and yank them out
  9. 2thousand5four
    Virginia
    Here's a few pics I took earlier [​IMG][​IMG][​IMG][​IMG][​IMG]
  10. thesman727
    thesman727 Full Access Member
    US
    Really a big fan of those 4x4 decals you have. Those aren't stock they're from a newer generation right?
    Insert tab A into slot B and........pound it with a hammer!
