cvs can do what youre talking about when they go bad. they can also get a little vibration feeling to it also.
I was worried the cv's were binding with the added lift.. They're at a pretty ify angle How do I check if they're for sure bad? Before I spend $180 on new axles Sent from my iPhone using Tapatalk
Got everything torn apart... I can't figure it out. Hubs don't have any movement. Lower ball joints don't have movement. I'm not really sure how to test is a cv axle is bad or not Sent from my iPhone using Tapatalk
Dylan said they were new Moog links/bushings. I'm still thinking Dylan could have checked the CVs with the tires mounted on it. Maybe it's more of a mystery sound and nothing is loose or breaking??? Galaxy S4 Cetane Powered Android
Turns out the upper A arms where fairly loose where they mount to the frame. I tightened them as tight as I could. It fixed 75% of the clunking. Something Still makes noise Sent from my iPhone using Tapatalk
I put my gopro underneath and drove around to see if there was anything abnormal looking.. Everything looks fine. The only thing i can possibly think of is like Will said. maybe the top nut on my bilsteins came loose or aren't tight enough? I might pull the spacer off tomorrow and see if they are tight or not. If i still can't find anything i'm taking it to the shop that installed my lift..this is ridiculous. It's gotten to the point where i hate driving my truck now because of all the clunking.
