  1. 2thousand5four
    Virginia
    Most recent pic of my truck after today's body lift experience [​IMG]
    That bad huh?
  3. 2thousand5four
    Virginia
    It was going fine until I tried to remove the bed bolts. They broke free from the nuts just fine but once they broke loose from the nuts I couldn't pull them through the bed idk why. It's with all of them to, they are all about 2 inches above the bed and that's the furthest out I could get them. I'm just gonna cut the heads off tomorrow and pull them out the bottom. Then I got all the cab bolts out except for the one on the passenger side core support. It's seized in the bushing so I'll probably cut that and just drill it out since I have to drill out the threads any ways
  4. 2thousand5four
    Virginia
    [​IMG]That's as far up as I can get them
  5. Roush PSD Interceptor
    Yep the cut and replace method.
  6. 2thousand5four
    Virginia
    Yep just have to get an angle grinder, but I'll get one tommorow at work. I'm hoping the body bushing is easy to drill out. That's really my main concern. I'm hoping that once i get the grinder it all goes smoothly and quickly
  7. thesman727
    thesman727 Full Access Member
    US
    Get an air chisel and poke them out
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  8. 2thousand5four
    Virginia
    I would but I don't think my air Compressor is big enough to run air tools. I got the heads cut off tho. I got all the lift blocks put in except for the ones under the core support
  9. 2thousand5four
    Virginia
    Still not done. Just have to extend the fuel lines, mount the rear bumper, and still have to put the blocks in under the core support. The bushings are toast so I had to order new ones and they won't be at advanced auto till Wednesday
  10. 2thousand5four
    Virginia
    Finally finished the lift. Now I'm desperate for some gap guards and 35s lol
