08 stx 4x4
Discussion in 'General Discussions' started by Ak 08 stx, Nov 1, 2013.
  1. ak_cowboy
    Does it do it all the time, or only in 4wd?
  2. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    I havnt tried it in 4wd drive yet, so far only in 2wd it makes the grinding sound
  3. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    Where does it sound like it's coming from?
  4. Ak 08 stx
    North Pole, ALASKA
    The front
  5. AK SNO RIDER
    Soldotna, Alaska
    Wheel bearing?
  6. Ak 08 stx
    North Pole, ALASKA
    I have no clue, when I get time
    Tomorrow I will jack it up and see if the tires move at all
  7. cowboy
    Iwe solenoid for sure.
  8. Ak 08 stx
    North Pole, ALASKA
    ok its been a while since I did update this, about a month ago I got some new tires on the truck 245/75/r17 and now I am leaning towards a cat back exhaust system. looking for something that would have a nice rumble to it at highway speeds but not to loud inside the cab. I have found some, but the shipping and handling rates for here are outrageous
  9. Ak 08 stx
    North Pole, ALASKA
    Ok, so I replaced the IWE solenoid in the truck and yes I did out a little dielectric grease on the connectors. Went to go test it out and turns out that is not the problem. The front hubs are basically shot, metal on metal grinding. When I was testing it out on ice, I did roll down the window and did some donuts and when I turned the wheels that's when I heard the metal grinding noise. [​IMG]
  10. Ak 08 stx
    North Pole, ALASKA
    Now my passenger window is not rolling up. Switch on the driver side doesn't work at all. But when I go to the passenger side it rolls down but not up. So either I got a bad motor, regulator or the switches are bad. Going to mess around with it when I get home and see what I can do to get the window rolled up before it rains.
