  1. 2thousand5four
    Virginia
    Some goodies showed up today. More will be here soon[​IMG]
    Sent from my SM-G920V using Tapatalk
    Precision measurement tool !
    2thousand5four likes this.
  3. 2thousand5four
    Virginia
    The thing is pretty cool lol measures down to .0005 of an inch
    What brand of dial
    indicator is it?
  5. 2thousand5four
    Virginia
    There no brand in the add, I don't remember seeing one on the indicator either. Hopefully it's accurate, it's wasn't a super expensive indicator. I'll do a few test measurement before I do the gears with it eBay http://www.ebay.com/itm/131900081811
  6. 2thousand5four
    Virginia
    Actually the brand says Taylor tool works
  7. 2thousand5four
    Virginia
    Tommorow is the big day
  8. Roush PSD Interceptor
    Send some pics if it isn't to much trouble.
    Otherwise wrench on !
  9. 2thousand5four
    Virginia
    I may throw together a write up too
  10. 2thousand5four
    Virginia
    Turns out both my Belleville springs for the trac lock where screwed and Ford doesn't make them anymore. So off course the only way to get them is to buy a Yukon rebuild kit that's $200 . So I went ahead and ordered that and some home got free overnight shipping but with this storm who knows when it will be here. I'll return the other clutch packs I got. Apparently these Yukon ones are supposed to be better than ford so we will see. I can pattern the gears either cause Motive gear sent me a screwed up pinion nut
