here she is guys!
Discussion in '12th Generation F-Series : 2009 - 2014' started by Pity7700, Dec 15, 2014.
  1. Pity7700
    Would have been nice to put one in, that was a messy job.
  2. Bdons-SD
    My superduty trans is the same way, minus the pump, I just used a tiny funnel, took a while but it got it done. No drain plug though. Expedition had a plug, that was convenient ha ha
  3. Roush PSD Interceptor
    Whaaaa?
    That bullet poofed tran no
    long dippity stick?
  4. Bdons-SD
    It has the long dip stick in the factory spot, just needs a tiny funnel and it takes a LONG time to fill. You'd think on a $4000 bullet proof trans they would have at least put in a drain plug though.
  5. Pity7700
    This no trans drain plug thing is dumb.
  6. Roush PSD Interceptor
    FML y'all must think when
    time for trans fluid / filter
    change.
    I use those long deep funnels from Walmarto Brendon,
    Holds quart 1/2 @ a time.
    Easy pie filling.
    Pity7700 likes this.
  7. Bdons-SD
    Ima get me one of them.
  8. Pity7700
    Those things are pretty cool.
    Bought one to change the diff fluid on my 02, slowest fill job ever!!
  9. Roush PSD Interceptor
    Best thing I've used of diff refill was 3/8" OD
    vinyl tubing heated very hot then pushed onto
    the nipple of the quart bottle of the synthetic oil.
    Makes it easier to hold bottle upside down with
    1 1/2 ft. of hose to maneuver around the
    diff housing and other obstacles.
  10. Bdons-SD
    I've done something similar using pvc pipe fittings on our excavator. There's only a 3"-4" gap between the oil fill and the main engine compartment ceiling ha ha, can't fit an oil container in there.
