There was a bar installed already when I got the truck. So only took 20 minutes to splice in new wires for my bar. Switch is on the left side of the steering wheel.
Tinted some windows. 5% on the shell and rear windows. Going 35% on the fronts Sent from my SM-J737A using Tapatalk
Looking good on the tints so far. Staying under the tint radar is good unless ya can get a dr.s note. Sent from my SM-G973U using Tapatalk
Got the test of the windows done 5% over the factory in rear. 35% on the fronts Sent from my SM-J737A using Tapatalk
Found some rust on the rockers. Also found out why my rear drivers lock wasn't working Sent from my SM-J737A using Tapatalk
That tint job is nice ! Great you found the rust before it gets ant worse. Agh, hack solder job instead of attaching a new insert connector to the wiring end.
Thanks. Glad I saved the fronts till last, was a little rusty on the first two lol. Yeah, I'm going to order a new harness. Going to try and por15 the rockers at some point also Sent from my SM-J737A using Tapatalk
Grabbed an N-Fab light bar for $50 and put it on. Going to run four KC Daylighters got now. Maybe jump to some lightforce down the road, or a lightbar in the grille Sent from my SM-J737A using Tapatalk
