Expedition front suspension
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by 1935 Ford, Aug 26, 2019.
  1. 1935 Ford
    1935 Ford Junior Member
    Strathmore
    I need to do the upper control arms / A arms .the upper ball joints are sloppy bad . I looked them up and they show the air ride like mine shows different than the standard all wheel drive . I checked Auto Zone but cant find upper arms for air ride suspension ,is it different from the coil all wheel drive ?Auto Zone is no help.
    @1935 Ford
    Lost of replacement ball joint options on rockauto.com many say "does not fit OE control arm" rockauto has the replacement upper control arms. Look through this listing to see if it has what you are looking for.
    These are in the Daily Driver Blue Section
    MOTORCRAFT MCSOE27 {#5L3Z3085C} $67.79 Upper Left 4WD Air Suspension
    The listing does not say excludes air ride
    MOTORCRAFT MCSOE25 {#5L3Z3084C} $67.79 Upper Right 4WD Air Suspension
    use discount code: 00A808C54DFCED in the "How did you hear about us?"
    during checkout.
    2001 Expedition 4x4 Air Ride
    https://www.rockauto.com/en/catalog...,4.6l+v8,1372384,suspension,control+arm,10401
    1935 Ford likes this.
