1999 super duty truggy build
Discussion in 'Under Construction' started by AKBray907, Sep 28, 2020.
  1. AKBray907
    so its been a while haha, copying this from the other forum. Figured yall would enjoy it
    So a little late but in order to keep a log of the work we do on it, better late than never! So we started with a 99 SD f250 v10. The truck came with tires 47x21.5 and was pretty roughly cut to just get them on it in order to store the vehicle. Our plan was to build a very capable hunting buggy to use up here in Alaska as well as an overall exploration rig as well as a project for my brother, dad and I to do together. We are no strangers to large projects and we wanted to be able to start pushing further back into the hunting grounds so it made sense. So here it goes!
    from when we first went to go buy it
    tow truck driver was loading it and popped the bead on the rear pass tire. he was cool with taking still though and went for it
    seemed sketchy to us haha
    47s vs 35s haha
  2. AKBray907
    so first step was to get it inside and start thawing it out and assessing where its at.
    got a spare set of smaller tires to make moving around easier
    original dana 50 and leaf springs
    time to go, dana 60 and 4 link on the way
    more cutting
    old suspension cut out and new dana s60 slid in place with the coils. just a mock up but more to make us feel like we are making progress
  3. AKBray907
    So the truck came with quite a few parts, including a Rize 8" lift 4 link long travel kit. However it came off a wrecked truck so we had to resection the damaged arm. The truggy is going to be an offroad only vehicle so some of the stuff we did was far more practical vs aesthetically driven.
    the bent section of arm cut out and new gusset plates cut for the sides
    started to weld it in
    all welded up
    the old bent section of arm
    some paint and should work great
    so the rims that came on it wer for an obs f250 and used adapters. Definitely wanted to omit the adapters so we got some pressed h1 centers that we will install into the rims to convert to the newer sd bolt pattern. more on this later
    the old dana 50 removed
    playing with the new axle a bit
  4. AKBray907
    so since the lift was meant for an 05+ truck we had to do some figuring out on the upper link brackets since we didnt have the factory radius arm brackets the 05+ trucks do. We used the common 4 link calculator and a bunch of calculating to find the best position for the upper link mount and then cut then designed a simple bracket and cut them on the plasma table.
    the lower link brackets from the kit
    lower links installed breifly
    also installed the spring towers. most holes were in the 99 frame, only needed to drill 2 or so on each side.
    also decided we were going to need some much larger jack stands so these were purchased
  5. AKBray907
    continuing
    cutting the plates on the cnc plasma I built. still some tweaking to do but fun to be able to use it
    links mounted
    on with the front suspension
  6. AKBray907
    so the next thing we needed to address before continuing
    steering box tap locations
    tossed the hydro ram up there to see what spacing we were working with
    new braided brake lines
    new brake lines, suspension starting to come together
    on the front suspension is the steering. The plan was to run a steering assist ram, so needed to tap the factor box and install it before we installed the lift drag link crossmember.
  7. AKBray907
    front lift on, now to wrap up steering components
    used a hydroboost pump and added AN fittings
    first load of tubing in!
    tossed the big tires on to see how she looked.
    ended up just getting the psc dana60 ram mount vs fabbing our own. saved time and was a nice piece
  8. AKBray907
    wanted a little break from the suspension work so moved onto the front bumper fab. started by plasma cutting some frame horn adapters and then the tube work fun could begin
    went with Runva winches, so far have been really pleased with them and the only ones we could get shipped up in a decent time. Partially covid and partially because no one wants to ship big winches up here and we had a small time frame so they were chosen. one for front and rear.
    C channel welded to mounts
    first tube to be bent
    will trim out later
  9. AKBray907
    tube work continues
    the trickiest bends were these small bars for the fairlead mounting
  10. AKBray907
    a quick spin around the neighborhood.
