2021 remote start
Discussion in '13th Generation F-Series : 2015 - Present' started by thesavo, May 8, 2021.
  1. thesavo
    thesavo Junior Member
    Albany, NY
    Does anyone know if the remote start plug n play kit from 2011-2014 f150s will work on a 2021?
    I get that the fobs are diffent styles, so I would need the switchblade key with a 2x button.
    I was able to add oem remote start to my 2014 edge by adding the tpms anteena, programing a key with a 2x button, and enabling in forscan.
    My brother has spotty cell coverage so using Ford pass is intermittently successful.
    Thoughts?
    Sent from my SM-N975U using Tapatalk
    @thesavo
    Welcome to FFS
    See this one on the 'Jungle'
    https://www.amazon.com/KICKY-RIDE-C...fdcac&pd_rd_wg=qU5Fr&pd_rd_i=B07GH7CDMM&psc=1
    FORScan, great tool.
    Bought OBDLink MX - bluetooth, came with TORQ
    app.
    Laptop is my way to get in, so much easier.
    All I had to do on wife's 2013 Explorer PIU was
    add hood pin and Edit 2 lines of the codes,
    program two 5 button fobs I bought on fleabay.
    Not sure what is available for the 2021 F-150.
    Check the FORScan Forums though.
  3. thesavo
    Albany, NY
    Yes, forscan forums are next
    I check accessories. Ford. Com and it's not listed as compatible. I think some models changed since 2020 and it's going to take some new discovery.
    Ford is 'redonkulous' now for Rotunda Service
    and some of the Techs don't know their butt from a
    yellow jacket's nest in the ground.
    Licensing it is over $900 a year and cable for your laptop is
    $100+
    No wonder the Russ-skis hacked into modules and sent it out
    as freeware.
  5. Roush PSD Interceptor
    The pic on 'Jungle' tap in cable for harness in steering column
    and brain box.
    I used to do these in the VATS and PATS days with DEI key boxes
    under the dash.
    Long gone are those.
    Digital encoder boxes now.
  6. Roush PSD Interceptor
    For $110 if one has Prime...
    Not to shabby.
  7. thesavo
    Albany, NY
    Thanks for the suggestion. I'll compare the options. I remember the bad old days before ignition t-harness and having to splice wires. Not too reliable back then.
  8. Roush PSD Interceptor
    Be sweet if Global Windows were left in the modules like Explorer were.
  9. thesavo
    Albany, NY
    No mention of global in the 2021 owners guide
    Having to splice in resistors to deal with GM VATS was terrible.
  10. Roush PSD Interceptor
    Not so bad.
    I had Electronics Training and ran 20K units at a
    Chassis Upfitter from '95 to 2000.
    Could make the older quad relay system to run off
    older alarm systems for window controls from remote
    key fobs.
    Time consuming, but it worked.
