76 F100
Discussion in 'Under Construction' started by justruckin, Jun 23, 2021.
  1. justruckin
    justruckin Full Access Member
    hopewell
    got the new rad for it today .... this should help. still has the original 46 year old camper specal rad in it. note.. if your truck don't have factory A/C you will need to get the rad hoses for A/C as the inlet and outlet are the same size as the rad for a truck with factory A/C[​IMG]
  2. justruckin
    hopewell
    got a 4.10 gear set and 31 spline axels .... and a new door.. orderd a mini spool [​IMG][​IMG]
  3. justruckin
    hopewell
    put the new heater core in it so i finished up the dash .... new pipes and mufflers .... new tank and sender .... put the spool and the 4.10 gear set in her but the 31 spline axles had a differnt bearings so the pumpkin didn't get put in..... i hate spiders.
  4. justruckin
    hopewell
  5. Roush PSD Interceptor
    Those 'DuraSpark' Ignition pack boxes used to be a common item asked
    for when I was Assistant manager at the Big Chain Parts Store 1990's.
    Even had one go out on me driving a rental U-Haul Sunday night one time.
    I put the Pertronix Electronic System in the 1974 FE 360.
    Never a failure there.
  6. justruckin
    hopewell
    new arm bushings ... and the stealies ... i like the look better. now to find the perfict dog dish for it .... old school sleeper cool ....
  7. justruckin
    hopewell
    ya ..... i know thay were prone to fail .... so i keep one behind the seat.
  8. justruckin
    hopewell
    got the new LED headlights in her. new plugs ( the rite ones) fixed the exaust leak that was driving me nuts. found out the boss 302 vac advance for the timing is way to touchy and will have to play with it. good thing its ajustable. .. got both floor pans ready to go in tomarow. ... one step at a time .... she will get there.[​IMG]
    [​IMG][​IMG]
  9. Roush PSD Interceptor
    @justruckin
    I see many of your photo links a 'broken'.
    I'm looking to see why you can't post in the 'For Sale' area..
  10. justruckin
    hopewell
    i will sell it ... but figured id fix it up first .... so its not for sale yet just because i can't get what in in it the way it is. ...
