Save $200 on AMP Research PowerSteps – Limited-Time Offer!
Discussion in 'CARiD.com' started by carid, Sep 9, 2024.
    Looking for the perfect running boards for your truck or SUV? We’ve got you covered with a range of options from AMP Research, designed to give you both style and convenience. The PowerStep Xtreme is built for tough conditions. It extends when you open your door and tucks away when you close it, keeping things sleek. With a tough surface for grip and weather resistance, it’s ready for mud, snow, and everything in between.
    If you’re all about the latest tech, check out the PowerStep Smart Series. These boards deploy automatically with wireless technology, making access easier without you lifting a finger. Plus, they come with built-in LED lights, so you’re always stepping safely, even at night.
    Got a lifted truck? The PowerStep XL is just what you need. It offers a wider step and drops lower, so getting in and out of your vehicle is a breeze. Like all AMP Research boards, it’s durable, weather-resistant, and gives you the convenience of automatic retraction. Perfect for anyone who wants a rugged yet refined look.
    AMP Research® - 6" PowerStep Xtreme™ Black Running Boards
    https://www.carid.com/amp-research/6-powerstep-xtreme-black-running-boards.html
    Note: Choose your specific model in "Product Options"
    Features:
    • PowerStep Running Boards produced by AMP Research are original factory equipment on some vehicles
    • Running boards extend outward when doors are opened, then retract flush underneath the vehicle when doors are closed
    • Ideal for off-roading where traditional fixed-in-place running boards may become damaged due to ground clearance issues
    • Running boards are triggered automatically when any door on the corresponding side is opened or closed
    • Sealed power motors mount directly onto the folding linkage assemblies with ease
    • Running boards extend and retract in approximately one second
    • Safe for young children because pinch protection sensors will reverse the direction of the boards if resistance is detected
    • Each side is rated to support 600 pounds
    • LED Lights illuminate boards when deployed
    • Comes with a controller module which you can mount under the hood and wires directly to your battery
    • Aggressive design for extreme traction, all-weather performance made from high-strength, die-cast aluminum components and maintenance-free, self-lubricating bushings
    • Bushings are sealed for protection against grit and the elements and require no lubrication
    • Legendary reliability with durable, high-texture powder-coat finish to resist corrosion and maximize grip
    • Precision stainless-steel pivot pins for rock-solid stability, OEM-quality motors, drive system, and wiring harness that set the industry standard
    • Warranty: 5 years / 60,000 miles
    • Manufactured in the United States
    AMP Research® - PowerStep Smart Series Black Running Boards
    https://www.carid.com/amp-research/powerstep-smart-series-black-running-boards.html
    Features:
    • No need to install manual override switch. In App Override Switch upgrades the Powerstep system to allow in-app manual override of the deploying steps and LED lights.
    • Profile has been developed to complement and flow with the chiseled design of new body style trucks.
    • Low Profile LED kit includes an auxiliary port to power and operate additional LED lights.
    • Apps available for both IOS and Android.
    AMP Research® - 6.25" PowerStep™ Black Running Boards
    https://www.carid.com/amp-research/6-25-powerstep-black-running-boards.html
    Features:
    • Ideal for off-roading or other use where traditional fixed-in-place running boards may become damaged due to ground clearance issues
    • Safe for young children because pinch protection sensors will reverse direction of the boards if resistance is detected
    • Each side is rated to support 300 pounds
    • Comes with a controller module which mounts under hood and wires directly to your battery
    • Bushings are sealed for protection against grit and the elements, and require no lubrication
    • Die-cast aluminum construction and stainless steel pivot pins ensure a lifetime of freedom from corrosion
    • Running board surfaces feature a powder coated finish that effectively resists scratches, chips, and discoloration
    • Warranty: 5-years / 60,000 miles
    AMP Research® - 6.25" PowerStep XL™ Black Running Boards
    https://www.carid.com/amp-research/6-25-powerstep-xl-black-running-boards.html
    Features:
    • Add wow factor to your truck with AMP Research PowerStep XL™ Running Boards
    • 3" lower stepping surface than the regular PowerStep™
    • Automatic power-deploying running boards
    • Running boards extend and retract in less than a second
    • Low-profile integrated LED light system – standard
    • Attractive and durable black wrinkle coat finish that effectively resists scratches, chips, and discoloration
    • Textured back step for maximum traction
    • Step, die-cast aluminum-alloy components with an anodized and pre-coated, military-spec finish to resist corrosion
    • Precision stainless steel pivot pins for rock solid stability
    • Fully welded/integrated bracket system supports up to 600 lbs
    • Weatherproof, OEM-quality electric motors, drive system and wiring harness
    • Maintenance-free, self-lubricating bushing for all-weather performance
    • Great for lifted trucks
    • Warranty: 5 Years / 60,000 miles
    You can browse the full catalog of AMP Research products on our website:
  2. carid
    Right now, you can get an exclusive $200 OFF on AMP Research PowerSteps, making it the perfect time to upgrade your truck or SUV. Whether you’re looking for the rugged PowerStep Xtreme, the tech-forward Smart Series, or the wider PowerStep XL, this deal has you covered. The discount is automatically applied, so no need for extra codes—just enjoy the savings. But hurry, this offer is only available from 8/29/2024 to 9/30/2024! Don’t miss your chance to grab these premium running boards at a fantastic price.
    If you want to learn more about the AMP Research brand, please click the link below:
    https://www.carid.com/amp-research/info/about.html
    See other active promotions and coupon codes here:
