No heat?
Discussion in 'General Discussions' started by Big'un, Feb 9, 2011.
  1. sfb89
    sfb89 ROLL TIDE
    West TN
    i thought box heated up and the blend door opened wen u turned knob to heat to let it flow to the vents..
  2. Big'un
    it should blow heat constantly , since the blend door cant block the heat
  3. XXXDCXXX
    XXXDCXXX Full Access Member
    terrace bay ontario
    no the black box that houses the heater core
  4. XXXDCXXX
    terrace bay ontario
    thats exactly right
  5. TFIDDLE
    yes so without the blend door wont it be blowin cold lol?
  6. sfb89
    sfb89 ROLL TIDE
    West TN
    ok...so wat could it be? the box heated up good and the blend door was off...so why didnt the heat make it to the vents???
  7. Big'un
    ok then , with my blend door removed and the heater core bein open in the box it should blow heat ..... right?
  8. sfb89
    sfb89 ROLL TIDE
    West TN
    no with it off it should be blowin hot all time
  9. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    have you tried clearing the lines? last time i had cold air my lines were clogged and my vents were full of crap like leaves and what not.. there may be somethin in there blocking the passage.. just a thought...
  10. XXXDCXXX
    terrace bay ontario
    With the blend door off it has no chance to make heat
