No heat?
Discussion in 'General Discussions' started by Big'un, Feb 9, 2011.
  1. XXXDCXXX
    XXXDCXXX Full Access Member
    terrace bay ontario
    the other door was movin? but no heat to the vents? does the fan work?
  2. TFIDDLE
    here is a diagram to go by
  3. Big'un
    the one in the middle of the cab moves fine , i watched it earlier as sfb said ....... and yes i have the one off that screwgreen posted a pic of
  4. Big'un
    yes , no heat , and yes fan works
  5. sfb89
    sfb89 ROLL TIDE
    West TN
    the door in the tube was movin and no heat
  6. XXXDCXXX
    terrace bay ontario
    try puttin the door back in with it facing open so it should blow heat and see if that works
  7. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    Do you have coolant in the truck? i know it sounds stupid but the smallest things are usually the problem
  8. sfb89
    sfb89 ROLL TIDE
    West TN
    :facepalm: yes nitewolf
  9. Big'un
    the door hinges like a normal door like on a house ......
    and yes nitewolf
  10. Big'un
    with the door open would be the same as if the door wasnt in there
