I have a 2010 FX2 w/ 275/55/20s (32"). Dont plan on leveling it. Unsure about lifting it, although may in the future. If I were to keep the stock height and rake, what is the largest tire size I can use without rub or other problems? I've looked throughout a few other sites but the discussions immediatly turn to lift & Level recomendations. Any help, other than lift/level it?
Guys, Thanks. Unsure about the level... I occasionally pull a travel trailer and dont want it drooping in the back. More apt to lift, keeping the factory rake, and will more than likely do this when I return from the next deployment. Wouldnt mind a 2inch height increase all around. Will do some more research.
So get a leveling kit in the front, and get an AAL in the rear. I did that to my 2wd XLT prior to the body kit and it was perfect. I could run 33s no problem, no rub, no trim. And the AAL will make the truck level out when you put a load on it. I had a pallet of grass in the back and i barely raked up. Trailer is nothing. I think I have a pic of me towin my 72 chevy somewhere
