  1. 01f1502wd
    I will i will. gotta wait for a buddies dad to go out of town so i can use their shop. not sure when he will go out next..hopefully it will be soon.
  2. BlackThundah
    I got a question for you. What have you got on there to lift it now? A spindle,?,?, 4inch rear blocks? Does it sit level like that?
  3. 01f1502wd
    its a 3.5" spindle with a 2" coil lift and a 4in block out rear:
    id say it sits pretty level.
  4. BlackThundah
    Man thats a good looken truck. Thanks for the info. Ill probly end up doing that at sticking some nitto mud grapplers on mine next. But thats way into the future. Cant wait to see it with the lift!
  5. Northwoods4x4
    Northwoods4x4 BangBro
    Chula Vista CA
    Trucks coming along nicely:peace: Where did you get the spacers? Im looking into a set myself.
  6. 01f1502wd
  7. General Lee
    looks good man and those headlights look sick if you don't mind my askin, how exactly do spacers work? I just know they make the wheels sit wider
  8. Northwoods4x4
    Chula Vista CA
  9. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    All it is general is a block of metal the same diameter as your rotor that has holes in it to bolt up onto your OE studs then has other studs for your wheel to mount... check out my thread on it for a picture
    Sent from my DROID2 using Tapatalk
  10. BlackThundah
    01, whats the wheel or rim width you going with? Cause i can tell you man your fron tires are gonna spray crap all over your truck. Mine stick about 2 maybe 2 1/2 inches, and they spray road grime all over the place.
