Wheel Advice
Discussion in 'Exterior' started by CLPeller, Mar 1, 2011.
What size wheel?
  1. 17x9
    4 vote(s)
    44.4%
  2. 17x10
    0 vote(s)
    0.0%
  3. 18x9
    3 vote(s)
    33.3%
  4. 18x10
    2 vote(s)
    22.2%
  1. CLPeller
    CLPeller Full Access Member
    Alberta, Canada
    You got any pics of that set up? Did the tires stick out past your fenders at all? And would a bit more backspacing stop the rubbing?
    Thanks everyone else for the advice! I'm still torn on what exactly to do...
  2. c418
    c418 Full Access Member
    what wheels are you thinkin of anyway?
  3. CLPeller
    Alberta, Canada
    In all honesty, I really have no idea... ha ha ha. I was thinking the Incubus Recoil's, but I haven't really found anything other than that that I have liked. I like the bigger spokes, and the only thing I don't like about the recoil's is the dots around the rim. But I think I could get past it. If anyone has some other opinions on rims, post em up :waytogo:
    Here are the recoils
    And these are American Eagle 064 that a guy I know had, and I could have got them super duper cheap. But they rubbed terribly... With only 32" tires...
  4. alaskatabby
    Ohio
    I've got 33x12.5 on 17x9
  5. CLPeller
    Alberta, Canada
    ^^^ With just a level? Any rubbing issues or trimming that had to be done?
  6. Predatory Instincts
    Burger King's bathroom
    I've got 305/60-18's (33x12) on 18x9 with +10 offset, with a level and rub my aftermarket nerf bars at full lock in reverse to the left.
    All of them are different. Just like you could install the same leveling kit on two different trucks and get two different heights out of it.
  7. alaskatabby
    Ohio
    No level and no rubbing it's stock up front..
  8. westtnfx4
    No not any shots that would show/tell you anything. I'm running 35's on the same 2.5 level and nothing else so that should tell you something.
  9. iowaredneck
    17x9
