TunaSlayer Mod Progress
Discussion in 'General Discussions' started by TunaSlayer, Jan 16, 2011.
  1. Carolinaboy
    I wasn't thrilled about the idea until I saw the end result :drool:
  2. 97madness
    Different, but looks good. wonder how they would look smoked :hmm:
  3. TunaSlayer
    TunaSlayer Full Access Member
    Martha's Vineyard
    Its possible I might do a light VHT down the road. I like the contrast right now though.
  4. Carolinaboy
    How'd you wire them? To the parking lights?
  5. iowaredneck
    looking good dood different and unique
  6. TunaSlayer
    Martha's Vineyard
    Thanks, and Carolinaboy, you'll have to read the text to see how I wired them :)
  7. ak_cowboy
    How did you turn on your DRLs? Or did you just use the fuse box under the hood?
  8. TunaSlayer
    Martha's Vineyard
    I just spliced into the DRL harness. Not sure what you mean.
  9. CLPeller
    CLPeller Full Access Member
    Alberta, Canada
    Dude.... Wow!!! Those are amazing! I think I might be doing that to my truck once I get my level/tires on.
    But, question. Do you keep you DRL's on? I heard with HID lights you weren't supposed to keep the DRL activated because It's a lower voltage (or amperage, not sure) running to the lights and it supposedly bad to run the HID without full volts/amps?
  10. TunaSlayer
    Martha's Vineyard
    Yeah I've read that before but I honestly don't really care. I bought them from Jon To so I know if they go out I can replace them. I personally like the DRLs...don't know why others don't except for the voltage arguement. I only run my DRLs about an hour or less before dark.
